scottybo Posted November 7, 2013 Share Posted November 7, 2013 i say JC because he also started with an x reg finnesse 1.6 and put an older engine in with an older ECU. i want to ask about the cooling system......firstly is the standard 1.6 radiator up to the job, on the larger zetec engines secondly will the cooling fan still work on its own with the older ECU or will i have to wire in a standalone switch?!? and lastly about the temp guage, apparently the older ECUs dont work with the newer digi dials in the last of the escorts, is there any way at all to make this work or would i have to wire in a separate temp guage? i dont think wiring one in would be a difficult task i just have a horrendous fear of cruising around quite happily when unbeknown to me, my new engine is baking itself to death Link to comment Share on other sites More sharing options...
Stu Posted November 7, 2013 Share Posted November 7, 2013 The radiator fan was not controlled by the early ECU, it used a mech/elec switch in the water hose. Rad will be fine if you use a proper fan, not some junk slimline crap. Link to comment Share on other sites More sharing options...
scottybo Posted November 7, 2013 Author Share Posted November 7, 2013 The radiator fan was not controlled by the early ECU, it used a mech/elec switch in the water hose. Rad will be fine if you use a proper fan, not some junk slimline crap. i was going to use the original one, its an aircon model so i think its a bit beefier Link to comment Share on other sites More sharing options...
Stu Posted November 7, 2013 Share Posted November 7, 2013 Why would it be beefier? Where's your logic? Link to comment Share on other sites More sharing options...
scottybo Posted November 7, 2013 Author Share Posted November 7, 2013 Why would it be beefier? Where's your logic? the fan is like double thickness of a regular one, when i had that pro tech manifold fitted it touched the fan cowling but on models without AC it clears fine....ergo i guess the AC models have bigger fans Link to comment Share on other sites More sharing options...
Stu Posted November 7, 2013 Share Posted November 7, 2013 It wasn't clear if your comment was about the radiator, or the fan. Link to comment Share on other sites More sharing options...
bongo Posted November 7, 2013 Share Posted November 7, 2013 The temp gauge is 2 wires easy to wire to the dash gauge.i had to do this on mine. Link to comment Share on other sites More sharing options...
scottybo Posted November 8, 2013 Author Share Posted November 8, 2013 The temp gauge is 2 wires easy to wire to the dash gauge.i had to do this on mine. what about the fan? will it still fire up on its own and regulate the temps? Link to comment Share on other sites More sharing options...
bongo Posted November 8, 2013 Share Posted November 8, 2013 Fan should be ok,its just a switch in a circuit. Link to comment Share on other sites More sharing options...
