antonio31 Posted January 21, 2014 Share Posted January 21, 2014 Hi, I have done a conversion on my Escort mk6, from 1.6 16v to 2.0 16v Zetec silvertop. The ecu I use is DEEP model from mk1 mondeo, without pats, manual transmision and intern Edis. The engine has a lot of power on acceleration, but when i slow down or when i press the clutch the engine stalls. I also have had a rough idle and stalling issue. I made the led test and i only have the egr system error (327 (O,R,M) EGR feedback signal is/was low), which means that there is no problem with o2 sensor, iscv, maf and other sensors. I have the egr error because i have an aftermarket exhaust manifold and the egr system is not present in the car because i didn't want to drill the stainless steel manifold.Did anyone know if the engine 1.8 16v 130hp from escort or fiesta had the EGR system? I wonder if I could put a 1.8 130 hp ecu on my engine if this model doesn't have egr or if you have any other ideas to avoid the egr system. Thans a lot! Have a nice day! Link to comment Share on other sites More sharing options...
scottybo Posted January 21, 2014 Share Posted January 21, 2014 the 130 lump does come with egr. as mine had it when i got it. i havent fitted mine yet however. have you blanked off all of the egr bits and pieces yeah? Link to comment Share on other sites More sharing options...
JC Posted January 21, 2014 Share Posted January 21, 2014 I had the same type of issue and so did Ross. Turn out the injectors needed to be refurbed and new seals Link to comment Share on other sites More sharing options...
bongo Posted January 21, 2014 Share Posted January 21, 2014 also had this,i think its because the escort doesn't come with egr,but the mondy did so its not connected to the ecu etc...... so it throws up the code. Link to comment Share on other sites More sharing options...
scottybo Posted January 21, 2014 Share Posted January 21, 2014 My 1.6 si had egr and so does my 130 lump Link to comment Share on other sites More sharing options...
bongo Posted January 21, 2014 Share Posted January 21, 2014 My 1.6 si had egr and so does my 130 lump well thats that idea out then lol Link to comment Share on other sites More sharing options...
antonio31 Posted January 22, 2014 Author Share Posted January 22, 2014 the 130 lump does come with egr. as mine had it when i got it. i havent fitted mine yet however. have you blanked off all of the egr bits and pieces yeah? Yes, I blanked off the egr hole from the intake manifold. I had the same type of issue and so did Ross. Turn out the injectors needed to be refurbed and new seals I will try to check the injectors. Thank you for your answers. From what I understand, the 130hp models have also EGR, so if the problem with the idle is from that error, unfortunately i have nothing to do, because i don't want to drill the stainless steel exhaust manifold to put the whole egr system (i heard that a lot of people had problems with it and i don't see the point to put it).The best think is to put a standalone but it will cost me too much. Thanks again! Link to comment Share on other sites More sharing options...
