Mike-evans Posted February 4, 2014 Share Posted February 4, 2014 Car always runs hot. Recent new water pump and coolant, still runs hot. Just had a nose under the bonnet and, all the rad is warm (not blocked), heaters are boiling, all hoses are hot except the one on the bottom of the expansion tank!! Air in system? Whats the best way to get all the air out? Link to comment Share on other sites More sharing options...
SteveB Posted February 5, 2014 Share Posted February 5, 2014 Thermostat stuck shut? Link to comment Share on other sites More sharing options...
Mike-evans Posted February 5, 2014 Author Share Posted February 5, 2014 Yes possibly. The heaters do get warm very quick though and stay warm, does that mean the thermostat is opening? When fitting a new thermostat, is it meant to go in a certain way? Hole at top or bottom.... sure I've read that somewhere.. Link to comment Share on other sites More sharing options...
scottybo Posted February 5, 2014 Share Posted February 5, 2014 to get the air out. open the top of cap of the coolant reservoir. turn the engine on. walk away. come back an hour later lol i had to do this 3 or 4 times to get the air out of my focus Link to comment Share on other sites More sharing options...
Mike-evans Posted February 5, 2014 Author Share Posted February 5, 2014 Whats the best way to determine if its an air lock, or stuck stat? Heaters get hot very quick and stay hot.Bottom return pipe on expansion tank is cold.......all other pipes are hot Link to comment Share on other sites More sharing options...
scottybo Posted February 5, 2014 Share Posted February 5, 2014 take the stat out and run it for a day, see if its any better Link to comment Share on other sites More sharing options...
SteveB Posted February 6, 2014 Share Posted February 6, 2014 Yes possibly. The heaters do get warm very quick though and stay warm, does that mean the thermostat is opening? When fitting a new thermostat, is it meant to go in a certain way? Hole at top or bottom.... sure I've read that somewhere.. The hole is the air bleed so should be at top. Link to comment Share on other sites More sharing options...
HINRG Posted February 8, 2014 Share Posted February 8, 2014 Yes possibly. The heaters do get warm very quick though and stay warm, does that mean the thermostat is opening? When fitting a new thermostat, is it meant to go in a certain way? Hole at top or bottom.... sure I've read that somewhere..the hole goes to the top. its a breather hole Link to comment Share on other sites More sharing options...
Jacko_XR3i Posted June 10, 2014 Share Posted June 10, 2014 Sorry to bump an old'ish' post but I'm having exactly the same symptoms, so rather than starting another thread... does anybody know the outcome of this problem!? Thanks! Link to comment Share on other sites More sharing options...
