orangecords Posted February 16, 2014 Share Posted February 16, 2014 Common fan inop problem..... Have a new switch but need info on how to get the old one out without mullering the dash...... Can any of you lovely lot help please Link to comment Share on other sites More sharing options...
VanMan_Jas Posted February 17, 2014 Share Posted February 17, 2014 Common fan inop problem..... Have a new switch but need info on how to get the old one out without mullering the dash...... Can any of you lovely lot help please Do you mean the panel with three round switches?If so:Remove steering wheelRemove 2 Phillips screws from near instrument clusterPull off round switchesPrise out dash switches and disconnect. Eg. Fog switch, heated rear screen etcThe dash surround should now pull out with a bit of effort. Its held in by some clips that you can't see and will pull free.Once the dash surround is off, you will have access to the heater panel, attached to the dash surround with 4 Phillips screws I think. If unsure, by a Haynes manual, its all in there. Jas Link to comment Share on other sites More sharing options...
