mike13579 Posted April 15, 2014 Share Posted April 15, 2014 Hello people im new to a forum thought id start with that, iv got a gti in need of some serious tlc !!! Relatively low mileage but needs a bit of body work and...strut tops bottom arms drop linksfront bearings pads and diskpluss a few other bit lol however am also thinking of an engine change, iv red that the 2ltr silvertop zetec engine and box will fit in !? what else will need to be done are the engine mounts the same...any thing on tuning the engine aswel either my standard gti or the 2ltr!? Thanks guys Link to comment Share on other sites More sharing options...
stoo2000 Posted April 15, 2014 Share Posted April 15, 2014 Hi Mike, Welcome to the forum! You may find this topic useful: http://www.escortevolution.co.uk/forums/topic/102469-engine-conversions/ Stuart Link to comment Share on other sites More sharing options...
mike13579 Posted April 15, 2014 Author Share Posted April 15, 2014 Thanks I had a look at the link ,would I be able to use some of the parts off of my 1.8 engine ie sump, pick up and water pump? Link to comment Share on other sites More sharing options...
stoo2000 Posted April 15, 2014 Share Posted April 15, 2014 Thanks I had a look at the link ,would I be able to use some of the parts off of my 1.8 engine ie sump, pick up and water pump? Yeah, you'll need to use your sump, otherwise the engine will not fit. For the small cost, fit a new 1.8 Zetec waterpump Link to comment Share on other sites More sharing options...
mike13579 Posted April 15, 2014 Author Share Posted April 15, 2014 Thanks only other issue is the loom Im capable of doing most of the work but am I better of getting a auto electrician in to swap that and the ecu or is it simple enough? Thanks again Link to comment Share on other sites More sharing options...
scottybo Posted April 17, 2014 Share Posted April 17, 2014 Just a case of swapping a few pins so fairly simple Alternatively have you thought about upping your 1.8 to 130 spec? May be fhe easier option Link to comment Share on other sites More sharing options...
