Jacko_XR3i Posted October 11, 2014 Share Posted October 11, 2014 As the title, my fan hasn't been working for a while... I've checked all fuses, bridged the connection (and it works) tried another fuse box and changed the fan switch. What else can I try?Could it be an ecu problem?... reason I think it might be is because, I can't remember what I was doing at the time butI had the fan switch disconnected whilst the car was running and I reconnected whilst the car was still running (pretty stupid i know), which resulted in a pop as the terminals met! It hasn't worked since! Link to comment Share on other sites More sharing options...
horizon Posted October 11, 2014 Share Posted October 11, 2014 fan switch is in the top hose, many people change the sensor in the thermostat which is for the ecu Link to comment Share on other sites More sharing options...
Jacko_XR3i Posted October 11, 2014 Author Share Posted October 11, 2014 I've changed the switch in the top hose which is why im confused that it still isn't working.... Link to comment Share on other sites More sharing options...
horizon Posted October 12, 2014 Share Posted October 12, 2014 Sounds like a break in the wire. It is it's own wiring loom that connects to the main loom for earth and power. They can get brittle so worth doing a continuity check as this is really the only thing it can be if the sensor is brand new. Have you tried bridging the contacts on the sensor plug Link to comment Share on other sites More sharing options...
Jacko_XR3i Posted October 12, 2014 Author Share Posted October 12, 2014 Yep and it kicks straight in when I turn it on. Thats why I'm confused and running out of options, im not entirely clued up on this I've only done what I've searched on forums etc so any more ideas would be muchly appreciated! I suppose the next thing I could try is another sensor as im not sure if its a ford part thus not having the correct thermal range? I got it from a local motorfactors and the guy literally passed me a part over the counter without a box. Link to comment Share on other sites More sharing options...
davec Posted October 22, 2014 Share Posted October 22, 2014 If you run the car until it gets to the stage where the fan cuts in,have you got access to a multi-meter to test the hose switch to see if it's closed. Link to comment Share on other sites More sharing options...
Jacko_XR3i Posted October 23, 2014 Author Share Posted October 23, 2014 I could get hold of one... but how would I test it to see if it was closed??? Link to comment Share on other sites More sharing options...
davec Posted October 24, 2014 Share Posted October 24, 2014 Set the meter to test for continuity and when the car comes up to temp. place the leads across the switch terminals and if you get a reading the switch is closed, and working,if not, it's open circuit and needs replacing.The way you describe the fault I would say the switch is faulty.A further test you could do is place the sensor part in a pan of boiling water and repeat the above test. Link to comment Share on other sites More sharing options...
Jacko_XR3i Posted October 24, 2014 Author Share Posted October 24, 2014 Thanks ok I'll give that a try. I have put a new sensor on though and it still isn't working. I'll give it a try anyway and see what results I get as I suppose that way I can see if there is something else going wrong if the sensor is actually ok.... Link to comment Share on other sites More sharing options...
davec Posted October 24, 2014 Share Posted October 24, 2014 So if you short out the plug,the fan runs? You've fitted two new switches and these don't work? Are you running the car up to temp. long enough for the switch to kick in? Link to comment Share on other sites More sharing options...
Jacko_XR3i Posted October 24, 2014 Author Share Posted October 24, 2014 Short the plug and it works.Only fitted one new switch upto now. Car is a daily runner so it gets upto temp everyday when I get stuck in traffic on the way home so I have to sit with the blowers on full whack to stop overheating! :-( Link to comment Share on other sites More sharing options...
davec Posted October 24, 2014 Share Posted October 24, 2014 Ok,thought you'd fitted two switches.Try the meter and let us know what you find. Link to comment Share on other sites More sharing options...
