cyrus883 Posted October 16, 2014 Share Posted October 16, 2014 hi all ive fitted rs focus mk1 324mm discs and brembo 4 pot calipers but have ran into a slight problem the bottom ball joint is just catching on the disc and i mean just if uve fitted this set up and got over this plz let me know how thanks all steve Link to comment Share on other sites More sharing options...
bongo Posted October 18, 2014 Share Posted October 18, 2014 I have this conversion,what size spacers are you using behind the disc? 5mm is recommended but my ball joint rubbed so I took the angle grinder to it,which solved it but I then tried a 6mm spacer which worked,but you may have to take a bit of metal off the pad guides so they don't catch the disc. Link to comment Share on other sites More sharing options...
cyrus883 Posted October 19, 2014 Author Share Posted October 19, 2014 no spacers behind the disc mate that could be my problem they are only just touching tho as i can turn wheel by hand when bolted on Link to comment Share on other sites More sharing options...
bongo Posted October 19, 2014 Share Posted October 19, 2014 You'll Definitely need a spacer so that the disc sits central In the caliper.was the car already fitted with the kit. Link to comment Share on other sites More sharing options...
dalelc16 Posted October 19, 2014 Share Posted October 19, 2014 Have you tried putting washers behind the disc? Link to comment Share on other sites More sharing options...
cyrus883 Posted October 19, 2014 Author Share Posted October 19, 2014 I got the brackets from ebay I spaced the brackets the disc sits perfectly central of the calipers there is a part of the disc thet the pads don't touch I'm thinking of putting on my machine and taking a bit off the inside of disc where the pads don't touch Link to comment Share on other sites More sharing options...
bongo Posted October 19, 2014 Share Posted October 19, 2014 You get them from a seller called "caprisport"? If so they're the same as I've got,I'm pretty sure we have the same hubs as yours was a mtx box,(front starter), Yeah though I also have seen people milling a bit from the rear to clear the ball joint. Link to comment Share on other sites More sharing options...
