molly4 Posted December 5, 2015 Share Posted December 5, 2015 Just got a mondeo 2.0 petrol with gen 38k one owner ,lovely condition thinking about putting into my van ? will the tank fit the van . Link to comment Share on other sites More sharing options...
Mex Posted December 6, 2015 Share Posted December 6, 2015 Just got a mondeo 2.0 petrol with gen 38k one owner ,lovely condition thinking about putting into my van ? will the tank fit the van . You don't say which generation of Mondeo, so which engine does it have? A Mondeo fuel tank isn't going to bolt up to your van. Link to comment Share on other sites More sharing options...
molly4 Posted December 6, 2015 Author Share Posted December 6, 2015 sorry mex its a 98 sreg ,which tank will fit m /,thanks. Link to comment Share on other sites More sharing options...
Mex Posted December 6, 2015 Share Posted December 6, 2015 So it's a Mk2 with a block top then. Not sure about here but there's threads on FEOC about fitting a black top zetec into an Escort. I'm assuming the current engine is a diesel and that's why you want to replace the tank. The only difference I can see between the diesel and petrol versions of the escort van tank seems to be the aperture for the sender unit is bigger on the on the petrol version to accommodate the in tank pump. You could hack up the Mondeo petrol tank and the van's diesel tank so that you can fit the Mondeo fuel pump or you could get a petrol version of the van tank which may require an Escort fuel pump. It's worth checking if the Mondeo pump will fit an Escort tank first, well that's if you don't get a used tank with the pump still fitted. Obviously if you go down the route of cutting and welding tanks, make sure remove the pump and flush all traces of fuel first. Diesel version.http://www.qparts.co.uk/images/FD0269220.jpg#Petrol version.http://i.ebayimg.com/00/s/MTEwMVgxNDY4/z/HfcAAMXQV0BSJdRf/$%28KGrHqRHJFEFIbJltZgMBSJdRevlVw~~60_1.JPG Link to comment Share on other sites More sharing options...
molly4 Posted December 7, 2015 Author Share Posted December 7, 2015 cheers mex i could cut that & get it welded up need somthing to do xmas day lol ,ill do more homework o the matter m/ thanks. Link to comment Share on other sites More sharing options...
