Got my RS2000 font brake calipers at the weekend :D Are they easy to fit, i.e. do they simply bolt straight onto the hub? This the same with the discs? Gonna need to buy the discs so does anyone have any recomendations for what brand to go for and where to get them? (should i replace the pads if i'm replacing the discs?)
always replace pads at the same time as discs, that way if the pads are pited or owt they aint damaging the new discs :thumb:
The pads are pretty new, so could i not buff the pads and get any imperfections out? Am i better with after market stuff or standard ford stuff? Where best to buy them from then?
buffing sounds like a bad idea :evil:
ebc greenstuff pads is the best for normal road use in my experience 8)
tar-ox discs are the most durable apparently, although EBC have a good name X( too..
not sure on the cheapes place soz! :eek:
Gettin the calipers off and on is pi$$ easy mate, should have no probs. try not to get brake fluid all over the place mind :D
I found EBC pads are a bit hard for normal road use, tarox or red dot maybe??
Prices ?(
