Air filters/induction kit
reidy
I have the '94 single point injection CVH model, and have been told air filters/induction kits will improve the performance slightly, after looking at K & N filters, there aren't any actually available for my model of car, unless I'm missing something.....
The part that K & N come up with for my car is a flat panel one, whereas the one in my car is one of the circular type, maybe 2 inch high, by about 25 inches. If i knew how to get the damn pic's on here from my comp i'd show you, just wanted to know if there were any performance filters or induction kits available cos i cant find any!
Cheers for the link, if you mean the model E-9091 then how come there is a flat panel with it too? There's no flat panel in mine, just the oval one
Could just be a generic image ;)
there should be a page with the dimensions on somewhere, there was for mine :thumb:
EDIT: It is a generic image looking at it - theres 2 different filters there
Edited by escort_rs_van
Spec
E-9091 Product Specifications
Product Style: Oval Air Filter
Height: 1.875 in (48 mm)
Inside Length: 12 in (305 mm)
Inside Width: 7.625 in (194 mm)
Outside Length: 13.875 in (352 mm)
Outside Width: 9.5 in (241 mm)
Top Style: Rubber
Top Material/Finish: None
Filter Re-Oiling Amount: 0.82 oz (24 ml)
Weight: 1.5 lb (0.7 kg)
Product Box Length: 12.25 in (311 mm)
Product Box Width: 12.25 in (311 mm)
Product Box Height: 3.63 in (92 mm)
:thumb:
yes cheers, think that's the right spec, still don't understand why there's the flat panel one beside it :nutter:
Its to show the type of filter - i.e. its not a bolt on one its a panel one :thumb:
You dont expect them to take a picture of every single different filter do you? LOL
Although i agree they should probably take different pics of the different styles of panel
I also have a 1.4i escort and looking to get an induction kit whats the difference between the two kits on that link apart from the price?
Ones a full bolt on kit (similar to induction kit) ones a replacement performance panel.
You might need a different filter to that though mate coz theres more than one 1.4 engine (mine is different to that one for instance) ;)
:thumb:
