Steering problem
Markt8
Ok i been having a problem of pulling to the right when i take my foot off the pedal at 40mph+ and a problem of having to have the steering wheel pointed to the passenger side slightly to keep the car straight. I had new lower arms fitted not long ago, and tonight i have just replaced my track rod ends.
Now that ive replaced the track rod ends the car is very undriveable,
The steering wheel sits so unstraight pointed to the passenger side to keep the car straight and anytime i take my foot off the accelerator the car throws me into the other lane It pulls itself about 2ft right and i have to struggle to straighten it up
I dont know what to do with it now.
Anyone any ideas?
Mark
Almost certainly tracking. Better get it checked ASAP :thumb:
Did u count the turns to take off each side and use the same with the new un's?
One i counted 11 taking it off but when i put it back on it wud only do 10? Why would that be, 3 times ive had the tracking done in a month now :vangry:
have you checked all the various suspension & steering parts for signs of distortion and wear
Forgot to say getting a knocking from the passenger side which i thought was the caliper but ive checked it and its fine.
Havent looked at the rack, but my cv joint on the drivers side is fooked but i dont think that wud make any difference ?(
I'd recommend a 4-wheel alignment check & adjust to be on the safe side. don't wanna take too many chances with your steering mate
Could be something simple but best to make sure :thumb:
is there any point doing 4 wheel alignment cos the back ones cant be adjusted anyway???
DON'T GO TO KWICK FIT TO GET TRACKING DONE
i got mine done there and they messed it up loads of times i.e. they never made the steering wheel straight and they are expensive at £24 a time
Marcus
Deffo agree about Krap-Fit, Marcus. They usually employ trained monkeys - I've had 'em do tracking and only adjust one side leaving the steering wheel crooked :nutter:
The reason I said 4-WA was that there may be other probs involved eg past accident or sommat. If there's any probs a proper 4-WA should find it :thumb:
