Mell30uk Posted June 24, 2004 Share Posted June 24, 2004 Afew times now, when i have been on idle my Accelerator will stick on 1.500 and sometimes 2000 revs and then after a few mins just drop down again to 1000 and be fine for a week or so.. but this morning on the way to work after each gear change it was sticking ! so it would be at 3000 then 4000 revs and wouldnt drop down after each change ! so after about 10mins of this i pulled over and just sat there in Neutral and it was stuck on 4000 revs screamming at me ! then after about 4 or so mins it just droped back down...so i carried on to work and it was fine any ideas guys & girls ? Mel x Link to comment Share on other sites More sharing options...
JonC Posted June 24, 2004 Share Posted June 24, 2004 could be a clutch problem of some sort, or the throttle cable in the engine bay has been fouled by something and is catching and holding try lifting the bonnet and spraying a load of wd40 on the throttle lever on the inlet manifold its the bit that the black cable is attached to which sits on the top of your engine i could show a pic if i had an engine bay pic on muh pcwhat lump BTW? Link to comment Share on other sites More sharing options...
JonC Posted June 24, 2004 Share Posted June 24, 2004 the bit highlighted is throttle cable and where it goes into throttle body Link to comment Share on other sites More sharing options...
Mell30uk Posted June 24, 2004 Author Share Posted June 24, 2004 cool thanks, 1.6 16v Link to comment Share on other sites More sharing options...
Cyrix Posted June 24, 2004 Share Posted June 24, 2004 ICV? maybe a stretched throttle cable, damaged linkage? Link to comment Share on other sites More sharing options...
sime73 Posted June 24, 2004 Share Posted June 24, 2004 u sure its the cable and not the icv as cyrix said Link to comment Share on other sites More sharing options...
Mell30uk Posted June 24, 2004 Author Share Posted June 24, 2004 icv ? Link to comment Share on other sites More sharing options...
Mike C Posted June 24, 2004 Share Posted June 24, 2004 icv ? Idle Control Valve Link to comment Share on other sites More sharing options...
Markt8 Posted June 24, 2004 Share Posted June 24, 2004 When i bought my car it did this 3 or 4 times within a month but only when i started the car it would just rev up to 4k and stay there I sprayed the engine and around it WD40 and since i done that its gone Link to comment Share on other sites More sharing options...
Mell30uk Posted June 24, 2004 Author Share Posted June 24, 2004 cool i will give that a go thanks Link to comment Share on other sites More sharing options...
Ex-Finesse Posted June 24, 2004 Share Posted June 24, 2004 Hope it's sorted My actual pedal has a habit of sticking to the bottom when its held there for over 20 seconds or so..... so in 5th the second or so it holds itself there feels like eternity when you're doing 120+ Link to comment Share on other sites More sharing options...
