furry Posted August 14, 2002 Share Posted August 14, 2002 ok as i´ve done this i thought i´d share it with ya all!!!it´s easy when you try. http://upload.turbosport.co.uk/getpic.asp?File=200281422257610439.jpg standard and esc cos discs http://upload.turbosport.co.uk/getpic.asp?File=2002814222557688045.jpg this is the semi circle that needs to be filed down using a grinder. go down as far as the lip on the carrier Link to comment Share on other sites More sharing options...
furry Posted August 14, 2002 Author Share Posted August 14, 2002 http://upload.turbosport.co.uk/getpic.asp?File=2002814222742310599.jpg you´ll see where the abs ring needs to clear in the carrier http://upload.turbosport.co.uk/getpic.asp?File=2002814222742862301.jpg you´ll see the calipers are slightly larger!!! Link to comment Share on other sites More sharing options...
furry Posted August 14, 2002 Author Share Posted August 14, 2002 http://upload.turbosport.co.uk/getpic.asp?File=200281422313556530.jpgyou´ll also have to put 3 washers in between the hub and the carrier to get the caliper to sit nicely on the disc this also means yr need some longer bolts.also what is needed is some different banjo bolts shorter ones which are available from motorbike shopsta the all done!!! Link to comment Share on other sites More sharing options...
900ss Posted August 14, 2002 Share Posted August 14, 2002 Well done m8 Just one question,does the pedal "feel" the same ? Link to comment Share on other sites More sharing options...
furry Posted August 14, 2002 Author Share Posted August 14, 2002 there is a slightly spongier feeling but they stop so much better. Link to comment Share on other sites More sharing options...
RS2000 Posted August 14, 2002 Share Posted August 14, 2002 Not to sure about them washers surley the carriers ain´t sitting squarley & securley against the hub Don´t they flex a bit under presure? Link to comment Share on other sites More sharing options...
furry Posted August 15, 2002 Author Share Posted August 15, 2002 na there fine, this is what all the fiesta boys do to put them on there rs´s Link to comment Share on other sites More sharing options...
