Rhino Posted July 25, 2004 Posted July 25, 2004 hiya peeps, got a problem with my si. it's a 1998 ® and the immobilizer cuts in while driving. it is definately the immobilizer, hoping you guys know of a way to fix it or disable it. dont fancy fitting new ecu/locks/ignition barrel ect thanks peeps
Rhino Posted July 25, 2004 Author Posted July 25, 2004 have been told it could be the ignition relay or the fusebox. will have to investigate tomorrow. god knows how i will tell though, might have to get an auto electrician to have a look.
Tom_escort2004 Posted July 25, 2004 Posted July 25, 2004 you dont wanna be doing that, those bar stewards cost £40 odd an hour for farting about playing pokey with a test light check for loose connections and bad earths id suggest,somethings triggering it. does the immobiliser come on when your driving? so the car cuts out?
Rhino Posted July 25, 2004 Author Posted July 25, 2004 does the immobiliser come on when your driving? so the car cuts out? yep, and it bloody annoying <---lovin' these smilies
Cyrix Posted July 25, 2004 Posted July 25, 2004 IS the red light constant on the clock? I had it on mine and it was a loose connection somewhere nder the stering column, pushed and pulled a few connectors and it worked, only did it when i tried to start it. Think yors is more terminal cos its donig it while driving, Soulds like a typical fse box fault to me!!!!
Rhino Posted July 26, 2004 Author Posted July 26, 2004 well, i seem to have fixed it was something to with my amp i think. its fine with it disconnected, but no wires were loose. weird, but nevermind thanks for the help though
Rhino Posted July 26, 2004 Author Posted July 26, 2004 aarrrgghhhh spoke too soon, it's just started again, but its not making the car stop at the mo. the loose wire idea does seem to be the most likely problem
