Hi, is it worth changing the inlet manifold or maybe throttle body on my 1.8Si for one from a 130ps model? I mean will it give any useful power for the cash - and what actual parts do i need to change?
Maybe a chip and the 130 cams would be more worthwhile??
Advice from those who have done so please, not mere speculation.
Cheers.
Ok, nice one. I did post a question before about the Uni-chip, can't seem to find a lot of info, like how much and where? Am I right in thinking they are custom-mapped rather than being a DIY plug-in?
Jay.
The 130PS and 105PS inlet manifold are *not* the same. The runners have a different diameter and it does make a difference (as I have proven on a flowbench). Don't forget that airflow is power, there is no point in remapping your car (with a unichip for example) if you still have a restriction on your intake. How exactly do you intend to make more power with a unichip if you're not flowing any more air? ;)
You need the inlet manifold, throttle body, ecu, cams etc..
Manifold isnt dif mate, its identical. Ive had them side by side
I recommend you get one of these then...
Either that or some glasses.gif 8)
the main difference between 115bhp and 130bhp, is they have difffernt cams, slightly different throttle-body,slightly different ecu mapped out
I think you'll find those 'slight' changes are actually quite huge changes.. It's not easy to simply gain an extra 15-20hp on a n/a engine, especially a 1.8 without increasing the redline and whole power band.. The 130PS throttle body has about twice the flow properties over the 115PS one, thats a bit more than a slight increase!
If you contemplate using the 115PS inlet manifold, you'll never see 130PS.. ever.. (on n/a)..
many people have got over 130bhp using the 115ps throttle body
If you believe that, you'll believe anything :D (rolling roads dont count as measurement devices)...
And why not. Perfectly good device for measuring power of a car. Manufacturers use em. There are several people that have hit 130 with NA power. And several that have hit more. Is it Pricey who is running 149bhp & 148 lb torque? Thats almost RS2000 power from the zetec and running N/A
