Spax Adjustable Suspension - Shocks And Springs
djxl_da_beast
Spax adjustable suspension kit (shocks and springs) for all mk5 escorts and im told will fit mk6 escorts as well (using the mk6 strut tops) but im not 100% on this so find out for sure first.
It looks lowered about 60mm.
Info here
http://www.potn.com/p1260050.htm
Need the space as im moving hence £150 :cheers
Ah right ok cheers. How is it fitted on a mk6?
the tie rod is fitted to the strut directly behind it (looking "through" the wheel at the strut) where as the mk5 tie rod, atattches (sp) to the strut via a bar that sticks out at 90 degrees. dont quote me on that though, i've only seen mk5 struts in piccies, never in the metal :innocent:
