zetec head question
HoldTilSold_co_uk
im building a 2.0l zetec mk4 escort here: http://www.16vzetec.com/
i have a 2.0l block and want ro run 1.8 ported and polished head.
this will be ok wont it?
just worried a little incase it increases the compresion ratio too much.
also i'd just use a 2.0 head gasket yeah?
cheers
mike
I'm pretty sure the 1.8 and 2.0 have the same compression ratio. It's the 1.6 which runs higher.
Do some searching on the internet, should find a page of zetec tech stuff :thumb:
the problem is will they still have the same compression once the 1.8 head has 2.0 pistions under it?
mike
