ABS light
Pricey
Hi,
I'm not trying to insult your intelligence but first check the fuse, #2 fuse on pre 95 cars and #9 fuse on post 95 cars both should be rated at 30A. If these are ok then I'm afraid that the on board ABS control module has detected a fault in the ABS system, you'll need to go to a Ford dealer and have them run a diagnostic on the system, its up to you then wether you remedy the fault or let them do it.
