rear brake options
steve_sport_scort
ok people im really getting cheesed off the brake thing now,
so what are the options for the rearbrake discs on abs cars,
could you use escort cos rear cals, and thier abs i think, and the disc size is the same?,
or st170 these are fairly expensive, specailly when iv just spent aload on the rs2k ones,
or sorting out the abs for the rs2k ones?,
what does everyone think is the best option, i want minimum work and expenditure, and abs would be nice,
:D
:D
since the st170 brakes fit, could you not use the ones from the 2.0 zetec focus, as those would give you the brake disc look, be cheaper, and wouldnt look so out of place with the standard escort fronts, ?(
mine now has an ST170-spec rear set-up with ABS
:thumb:
how much did it set you back mate?
bet it look the mutts nutts tho,
does it fit straight to the escort beam, or does it need lots of modding :(
it was modded heavily and cost £500 plus a bit more for a new ABS sensor
:thumb:
Edited by Mike C
:thumb:
:thumb:
£500 that's 1/5th the value of my car :jaw:
theres got to be something cheaper that'll do the same job,
