Wierd noise???
DJC
First off, I apologise if this is in the wrong section.
Over the past couple of days my car has started to make a wierd noise when turning the steering wheel. It only hapens when going around tight corners and the sound can only be described as a loud twanging noise?? It also makes the same noise when straightening up after the corner. Any ideas???
Cheers
