Posted May 21, 200519 yr I know I'm thick but how do I change my main headlight bulb? Can't seem to get it out the back of the light. Don't wanna pull 2 hard incase I break it.
May 21, 200519 yr on a mk6 theres a coverwhich is holded on with a wire clip, relase that and the cover comes off, once inside theres a black plug which is pluged into the bulb, pul it over it should come off easy, then theres a wire clip that needs moving to one side to relase it, and then do it in reverse to get the bulb back in and sorted
