Posted May 23, 200519 yr Right as many of you know I have a garage load of parts for my engine....This morning I started stripping it down, so far I have fitted the ARP rod bolts and got the 4 branch manifold in position and bolted to the system, next job is to replace the sump and remove the head......... ..........I'm just having a breather at the mo, using the computer in the garage as I'm fecking filthy....lol.........I'll keep you posted as I have each break.....
May 23, 200519 yr using the computer in the garage as I'm fecking filthy....lol.........I'll keep you posted as I have each break..... <{POST_SNAPBACK}>What a posh git you are! lol 10 cars, and a pc in the garage lol Remember..........PICTURES SAY A THOUSAND WORDS
May 23, 200519 yr A PC in the garage!! I have only just got a doorlock for mine, 5 steek wheels and a broom handle, should keep the thieving bast*rds out. good luck with the engine work what you hopin to gain from it?
May 23, 200519 yr Author Right, break time...got the old cams out and the head off, next job is to build up the new head with the bodies, new cams, verniers etc and fit to the block......
May 23, 200519 yr same as what i'm doing basically except i'm sitting here still in my jim jams and someone else is getting dirty hands
May 23, 200519 yr Author Time for another break....lol.....Still cleaning up the block, the old gasket has stuck fast in about 4 places and is being a right bitch to remove.... , still onwards and upwards, the new head is ready at least... , I'm hoping to have it running before I go to work tomorrow night.........
May 23, 200519 yr Author using the computer in the garage as I'm fecking filthy....lol.........I'll keep you posted as I have each break..... <{POST_SNAPBACK}>What a posh git you are! lol 10 cars, and a pc in the garage lol Remember..........PICTURES SAY A THOUSAND WORDS <{POST_SNAPBACK}> I've posted some pictures for you mate.........
