Posted May 26, 200519 yr Im going to paint my Brake Calipers and Drums silver tomorrow, but first i need to know the basics........ - How Do I Prepare Them For Paint? - What Type/Make of paint should i use? - How Should i apply the paint....Spray/Brush? Any info would be great... Terry
May 26, 200519 yr just give the surface's a good rub down with a wire brush and then brush on a couple of coats of Hammerite in ur chosen colour
May 29, 200519 yr i painted mine brush style with couple of coats of hammerite.. the most time taken was getting the loose rust off the calipers and drums, there was quite a lot of there! Looks wkd now though, it's a subtle easy but good looking mod
May 30, 200519 yr spraying is easier, i did this to my old escy, but the only prob is you only get enough for 2-3 light coats for each cal/drum, so with a few months of driving stone chips set in and then it soon rusts again, use a tin and brush, its cheaper, you get loads more, and you can do more, thicker coats.well thats my opinion
