sorted_mk6 Posted September 5, 2005 Posted September 5, 2005 right, i sorted the prob wit the bolt, retaped it and used a bigger bolt, but damn thing has worked loose again.wen i looked at it, weneva i put the steerin to full lock it puts a lot of pressure on the pipes and it pulls at the connections where the bolt is, i think thats why the bolt worked loose in the 1st place now.it is all fine until it hits full lock, then the pipes pull on that metal bracket and a bit of fluid leaks out, and obviously this puts the strain on the bolt then.plz plz plz anyone got any suggestions? wud be a big helpcheers
