Muzz Posted January 28, 2006 Share Posted January 28, 2006 I like how muzz says 'shafts popping out' Sounds so easy huh? Yeah it is ...apparently . Gonna get the low down tonight from my brother who is a gearbox specialist . Link to comment Share on other sites More sharing options...
bluliz Posted January 28, 2006 Share Posted January 28, 2006 And I'm bring a metal bar tomorrow to assult any bit of car thats gets in the way. Link to comment Share on other sites More sharing options...
Carl160180 Posted January 28, 2006 Share Posted January 28, 2006 Muzz to "pop the shafts" just cut the tie that holds the inner cv boot cover on, Cut the one closest to the gearbox (the largest end) and pull the boot back and then the shaft can be pulled out without loosing anyoil as it'll leave the end of the shaft still in the box Link to comment Share on other sites More sharing options...
Ex-Finesse Posted January 28, 2006 Author Share Posted January 28, 2006 (edited) Muzz to "pop the shafts" just cut the tie that holds the inner cv boot cover on, Cut the one closest to the gearbox (the largest end) and pull the boot back and then the shaft can be pulled out without loosing anyoil as it'll leave the end of the shaft still in the box Genius idea! End of play today, about an hour ago, this was the scene: Massive thanks to Ben Muzz and Rob who helped and were there for moral support! Also, quote from Muzz: "I wouldn't have fisting as my number one way to die..... maybe 4th" Looking forward to tomorrow, lets hope we get to put the engine crane to use! There are slight wiring differences between the cars, so I'm a little sceptical about being able to put the plastic inlet manifold on without extending a couple of wires for sensors. I'm also hoping the car will run with no re-wiring needed to the ecu multiplug!! Just like Andy C's!! Mine is external EDIS and K-reg. Been a good day though, cheers for all ya help guys EDIT: @ the orion's drivebelt!! It had split for a good 2 foot of it's length! All the fluids were a nasty colour too! Very bleck oil, nasty P/S fluid and dirty water Not to worry though, good to find it out! Edited January 28, 2006 by Ex-Finesse Link to comment Share on other sites More sharing options...
Scotteh Posted January 28, 2006 Share Posted January 28, 2006 seems like things are moving along wheres ur dad put his ferrari for the moment then? Link to comment Share on other sites More sharing options...
Ex-Finesse Posted January 28, 2006 Author Share Posted January 28, 2006 It's round the side of the house!! Link to comment Share on other sites More sharing options...
danposs86 Posted January 28, 2006 Share Posted January 28, 2006 Right im confused, what engine are you putting in what car? Link to comment Share on other sites More sharing options...
Muppje Posted January 29, 2006 Share Posted January 29, 2006 Putting the current Escort's 2.0L in the Orion, scrapping/selling the orion engine I guess, and using Ross' old engine or most of it for his new project for the Escort. Hmmm, there was me under the impression that there wouldn't be anyone there on Sunday and it'll all mostly be done, so said yes to covering someones shift at work.....FS but LOL thought you would've had more than that done by the end of the day, damn slackers Link to comment Share on other sites More sharing options...
father_ged Posted January 29, 2006 Share Posted January 29, 2006 when i get there, make sure u have a disc cutter, sledge hammer and a fire extinguisher. i will show u how to do it properly! Link to comment Share on other sites More sharing options...
Muzz Posted January 29, 2006 Share Posted January 29, 2006 Orion's driveshafts out in 10 minutes!!!! Engine is now ready to be lifted out. Hopefully the Escort can be done as quickly!! Link to comment Share on other sites More sharing options...
Simonez Posted January 29, 2006 Share Posted January 29, 2006 (edited) ahhhhhhhh wish i could of come be a right laugh is ralph gonna put the tbs on a 2.0? sim Edited January 29, 2006 by Simonez Link to comment Share on other sites More sharing options...
Gramps Posted January 29, 2006 Share Posted January 29, 2006 Top work guys keep it up.. Link to comment Share on other sites More sharing options...
Muzz Posted January 29, 2006 Share Posted January 29, 2006 Engine is just about out, however we have another problem in that Mike's car has just p1ssed brake fluid everywhere. After close inspection, it seems that the suspension has rubbed against the brake line coming from the ABS pump so we are now dismantling the braking system on Ross's old car to try and fit to Mike's, if this doesn't work fcuk knows what we will do as his brake down cover ran out 2 weeks ago . Link to comment Share on other sites More sharing options...
sidrick Posted January 29, 2006 Share Posted January 29, 2006 Nae Luck. Link to comment Share on other sites More sharing options...
Scotteh Posted January 29, 2006 Share Posted January 29, 2006 FPMSL!!! :roll: Link to comment Share on other sites More sharing options...
