Posted December 18, 200222 yr recently, ive been getting huge static shocks off the car's chassi....... like i mean real bad ones! they used to be tiny but ever since i earthed the sound system to the chassi its got worse, just about half an hour ago i got out the car, forgot about the shock even tho its been doing it for like 3 months, touched it, and it was the biggest one yet, my hand went numb for a couple of seconds.....any one know how to stop this?
December 18, 200222 yr get those big rubber strips on the back of your car, just like Del Boy's Capri Ghia
December 18, 200222 yr recently, ive been getting huge static shocks off the car's chassi....... like i mean real bad ones! they used to be tiny but ever since i earthed the sound system to the chassi its got worse, just about half an hour ago i got out the car, forgot about the shock even tho its been doing it for like 3 months, touched it, and it was the biggest one yet, my hand went numb for a couple of seconds.....any one know how to stop this? ..............you must wear wellington boots at all times around your car.Al.
December 18, 200222 yr have u tried disconnecting ur stereo and seeing if the problem is still there ??
December 18, 200222 yr while getting out of your car hold the metal part of the door before touching the ground.
December 18, 200222 yr while getting out of your car hold the metal part of the door before touching the ground. ............rust does not count as metal!! Al.
December 18, 200222 yr while getting out of your car hold the metal part of the door before touching the ground.............rust does not count as metal!! Al.
December 18, 200222 yr Thers loadsa things that could be charging you, but Id check your stereo first mate If it aint that, have a look round your house to see if any of the internal doors have "dropped" on their hinges. If they are rubbing the carpet as they open/close then that can "charge" you up hence the shocks. Truth that is mate. Jordan
