Heated front windscreens
Paulo
Had one on my old L reg Ghia. Was great to have, took about a min to defrost a frozen screen :D As far as I know it can be fitted into your car with the right looms etc
i've had a heated screen put in mine, you'll need the screen, dash switch and engine bay loom with relay, the loom from fuse box to dash switch is already in place. you'll need to plug loom into plug next to abs module and mount relay on bulkhead somwhere. si cabbys have them as standard and ghia x's
