Got to work this morning, got out to get a ticket and noticed a strange ticking noise comming from the engine. havnt had time to look at it, any ideas??
:cheers:
check ure oil :)
if its a wining noise it could be the water pump. nocking, then i would replace the oil/filter.
knocking but ticking lol
yeh i'll give em a try
:cheers:
any other ideas??
probably your tappets screaming at you to flush the engine and pour in some 5w30semi synthetic...
just read you have a zetec, was gonna say if its a cvh thats normal :roll: and what made you turn the radio down
lol, flush engine?? :baby:
i think i recall seeing a liquid you can buy from halfords which does this? am i right?
what actually does it do?
:cheers:
Add flushing solution to your oil & run it to operating temperature then drain the old oil out, replacing it with 5/40 semi synthetic oil & a new oil filter, voila, engene flushed & replenished :D
You mean 5w30 right peewee? This is a zetec engine he has...
Mine used to make a slight ticking noise when cold. Changed the oil and filter and was fine after that. :thumb:
how do u drain the oil?? yeh it is zetec
:cheers:
There is a 13mm bolt which you undo on the sump.
also check the exhaust gasket ;)
if its a ticking noise maybe its a bomb :eek:
just started the car back up on my break, noise gone, sorta was there at 1st, but after a sec it dissapeared. lol
any ideas????
:cheers:
It could always be the injectors they can make loud ticking :thumb:
