hi guy
ive had a idle problem for ages and spend loads of money at a ford garage to the tune of £500 which they wont give back and still cant repair my car.
i have cleaned the idle control valve but no change.
went to a different ford garage and they sugested unpluging the PCM.
i did this and at the mo the problem is solved.
just wanted to know what the PCM does if anyone can help
thanx
ryan
what is a PCM? I don't think i have ever herd of that.
its called a power control module thats in the panel in the footwell
If you talking about the small black box on the left hand side ( passenger side ) footwell, ... its not a PCM,
its a FCOS
Fuel Cut off Switch
It activates when you are involved in a sharp shunt, or a major accident.
Edited by SiV6Si
its a FCOS
ford main dealer to me the passenger side foot well is the pcm ?
its silver in colour and held in with a 10 mm bolt.
Fuel Cut off Switch
