Posted May 1, 200618 yr i am having a problem with my escort 1.8 si 1998 fuel gauge . when i turn my ignition off the needle drops all the way down , then when i restart it will go up again but it is not showing the true amount in the tank . this happened a few months ago but it was ok the day after but now it as hapened again i have just filled the tank and it it is only showing 3/4 full when i know it is full . when i turn the ignition off the needle would not drop down it would be always shoeing what was in the tank , can anyone help as this is really annoying . thanks
May 1, 200618 yr find the wire going to the guage and earth it, if the sender is ok the guage should go to full
May 1, 200618 yr Author find the wire going to the guage and earth it, if the sender is ok the guage should go to fulldone that and the gauge is ok , needle is droping all the way down when it used to always stay according to how much fuel in the tank it still moves but it is about 10mm short of its starting point , hope you no what i am trying to say . thanks
