Posted May 2, 200618 yr Well got the car back Saturday engine seems fine, got to run it in now for 1000-1500 miles I've done over 600 already!!
May 3, 200618 yr Author is it running on mineral/running in oil at the mo Al? Yes you are correct,mineral for the first 1000 then 15/40 semi. blackpool and back twice does it Great running it in with optimax £1 a litre or more! did they fix it for free? or was it not under warranty Not under warranty
May 3, 200618 yr is it running on mineral/running in oil at the mo Al? Yes you are correct,mineral for the first 1000 then 15/40 semi. blackpool and back twice does it Great running it in with optimax £1 a litre or more! did they fix it for free? or was it not under warranty Not under warranty what happened.. i cant remeber
May 3, 200618 yr Author is it running on mineral/running in oil at the mo Al? Yes you are correct,mineral for the first 1000 then 15/40 semi. blackpool and back twice does it Great running it in with optimax £1 a litre or more! did they fix it for free? or was it not under warranty Not under warranty what happened.. i cant remeber Not long had it and i could just hear the slight knock of the big ends! I've had a complete rebuild, new Crank,Oversized pistons,slight rebore,new conrods,rings,competition big ends,new mains,everything stripped and cleaned(head, valves etc) All new genuine Subaru gaskets,spark plugs,new timing belt,oil seals.I've also had a new 3 piece clutch kit.
May 3, 200618 yr Looks nice mate, bet your glad to have it back - fingers crossed its a good'un At over 3 grand it bl00dy outa be
