Help
mk6_escort
Hi
there is a sensor around the ignition barrel that reads the key code, check to see if the cable is connected and not damaged. Do you have the red key? does that work?
Dave355
Yes mate i have all 3 keys 1 red and 2 black none of them work
Where is the sensor and what does it look like?
Cheers
As said , do you have the red key as this is what you use to program it again.
Do check the sensor round the barrel in case you have knocked it?
Its a black plastic that surrounds the barrel, make sure its how it should be as in placement & connected
Cheers peewee just been out had a look, somehow managed to spilt a wire coming from the transponder reconnected it!! :blush:
The sweet sound of a running engine!!!
