Craig855S Posted July 13, 2006 Share Posted July 13, 2006 HOw do u check how much gear oil u have in ur box. When i changed my engine nothing came out of the bottom when i had the shafts out,but i thought the shafts went into a compartment seperate from the oil(a compartment filled with CV joint grease stuff) but if its not a seperate compartment then why didnt anything come out,maybe its empty,shud i drain it and fill it up with new stuff?and how do u do that? Link to comment Share on other sites More sharing options...
Muzz Posted July 13, 2006 Share Posted July 13, 2006 There is no dipstick on the box, so you need to undo the 6mm (I think) allen key bolt on the front of the gearbox and have a look inside at the level. Generally you should top it up until it is level with the hole, if it isnt, then I would suggest topping it up. Also the shafts go straight into the gearbox and once removed, box oil should Pee out everywhere. If it hasnt than the chances are it was probably fairly empty!! For reference, you want to be using 75/90 when refilling the gearbox oil. Link to comment Share on other sites More sharing options...
Craig855S Posted July 13, 2006 Author Share Posted July 13, 2006 would that explain a slight scratching noise when the clutch is depressed? or has the gearbox oil got nothing to do with the clutch? ive alwasyt hort the scratchin noie was a release bearing issue,even tho the clutch bites well. So,IB5. where is this allen key bolt,and is it easy to see into the oil level without using jacks,and where do u pour the oil in? could i do it with the car on the floor and without getting under it, i bought the oil when i done the engine change Link to comment Share on other sites More sharing options...
theresa Posted July 13, 2006 Share Posted July 13, 2006 would that explain a slight scratching noise when the clutch is depressed? or has the gearbox oil got nothing to do with the clutch? ive alwasyt hort the scratchin noie was a release bearing issue,even tho the clutch bites well. So,IB5. where is this allen key bolt,and is it easy to see into the oil level without using jacks,and where do u pour the oil in? could i do it with the car on the floor and without getting under it, i bought the oil when i done the engine change I'm assuming an Escort van gearbox is a similar layout to your car, so if it is, then the easiest place to see and get to the nut, would be to lie on the floor, on the passenger side of the car and sort of in line with the bumper, near the inside of the wheel, you will see the gearbox and the allen nut in front of you. To check the level, undo the nut and put your finger in and bend your finger down. If you get gear oil on your finger, then the level is fine, if not, then put some gear oil in that same hole, until it starts dribbling back out, then that means it's full. Checking it only takes 5 minutes and you don't need to jack it up. Link to comment Share on other sites More sharing options...
Craig855S Posted July 13, 2006 Author Share Posted July 13, 2006 the van may use the MTX. Ive searched IB5 and found some unconvincing results.not only is the wrong oil mentioned (halfords table said 80w90,which i bought) it also mentions that the IB5 has no fill hole or drain hole and is "FORD sealed for life" Link to comment Share on other sites More sharing options...
Muzz Posted July 13, 2006 Share Posted July 13, 2006 Like I said, the allen key bolt at the front of the gearbox.. Link to comment Share on other sites More sharing options...
Craig855S Posted July 13, 2006 Author Share Posted July 13, 2006 1.what oil will it have in it?2.Can i put this 80W90 in it3.If it currently has a different oil in can i mix the two4.How many litres does the box hold? Link to comment Share on other sites More sharing options...
Trig Posted July 13, 2006 Share Posted July 13, 2006 1.what oil will it have in it?probably ford factory 80/90w2.Can i put this 80W90 in ityes3.If it currently has a different oil in can i mix the twoyes4.How many litres does the box hold?until it runs out of the hole where the 6mm hex bolt screws in Link to comment Share on other sites More sharing options...
Craig855S Posted July 13, 2006 Author Share Posted July 13, 2006 right,im off to wang it in,cheers trig Link to comment Share on other sites More sharing options...
Craig855S Posted July 13, 2006 Author Share Posted July 13, 2006 hoyed loads in,and it didnt take much before it was spilling out.so i chucked it in to make as much of the old stuff come out as i could,then cap back on and sorted.(i opened it with a T45 cos i had no 8mm allen key, its waaay bigger than 6mm) Link to comment Share on other sites More sharing options...
