seat frame
Pelles
i dont think there really is any mate :) ever thought about longer bolts, and something like big thick washers to raise the seat?
nah mate, would be a pain in the arse and I dont know what implications that would have on the loading factor should the car take an impact.
How ever, i do believe there are aftermarket seats that come with the raising ability? if so ill bite the bullet and throw them in on top of my other plans....
I woulda thought you could just swap the frame over with a gti frame with height adjustment?
Ohh Ric...I like the dirty talk, tell me more!
Edited by Pelles
as above the frames are the same, it would just be a case of swapping tham over and running electrics to it to power the motor
Thats good, but im trying to order the darn parts and trying to explain to the guy what i need...dont think hes understanding too well lol
It is difficult to ascertain exactly what is required when retro fitting.
I dont know for example if the back seat frame from your vehicle is compatable with the base frame from the GTI
All the items are seperate.
When parts are requested that are a a standard fit for vehicle detail supplied there is no problem, but as i say i am
a little unsure of what to supply and the compatability.
get yersel doon the scrappies mate, my ghia had elec height adjustment aswell would likely pick up the whole drivers seat for little money. Just make sure you rub plenty dirt on it and point out the rips ;)
im liking your plan but i'm a lazy b*stard....i guess ill need to find a 3dr one? apparently the 5dr ones are different.
I think the 3 & 5 door fronts are the same fella except you wont have the tilt action on the 5 doors?
yea that would make sense....but what doesn't make sense is ford parts uk quoted me £445 for the seat frame!!!
Scrappies it is! :D
What models all have this frame? 3DR GTI and SI's?
yeah it'd have to be a 3dr so your seat still slides forward :thumb:
cheers ric,
I took the drivers seat off tonight....5 bolts, someone pinch me...it can't be that easy! :D
This electrical height adjustment motor, im not good when it comes to wiring in electrics...is there a guide somewhere?
Ill give the scrappies a call tomorrow, so its the 3dr GTI and SI that has the frame I'm after? are there any more models to broden my search?
ghias although I aint ever seen a 3 dr ghia. Electrics should be straight forward mate, you could just wire it straight to the battery, set the height you're after and then leave it unwired.
what? just run the positive and negs to the battery? i thought id need to run it through the fuse box...but that sounds relatively simple! :D
