dazzler24 Posted July 17, 2006 Share Posted July 17, 2006 Escort 1.6 zetecOver the last month car has lost power,espicially when going up hills,it got so bad it was only going up about 10mph,all that could be heard was the exhaust sounding like it had an hole in it(blowing).Its got to the stage where the car now will only start for a few seconds with a loud blowing noise from exhaust.The engine was getting very hot too.Could the cat be knakered blowing gases back through engine?please help Link to comment Share on other sites More sharing options...
Craig855S Posted July 17, 2006 Share Posted July 17, 2006 sounds like the cat has collapsed mate,if ur any good with spanners get under the car and take it off,have a look thru it see if it looks caved in,if so change it,if not test drive the car with the cat out and see if powers back (altho it will be VERY noisy)and make sure u tie ur mid sectiopn up while u take it for a quicik spin Link to comment Share on other sites More sharing options...
Trig Posted July 17, 2006 Share Posted July 17, 2006 I would have said cat, take it off and shake it out. and as scoop says, take it for a spin and see if its back to its usual self (although it would be very noisy) Link to comment Share on other sites More sharing options...
dazzler24 Posted July 17, 2006 Author Share Posted July 17, 2006 i give it a go cheers guys(when weather not so hot) Link to comment Share on other sites More sharing options...
dansGTI Posted July 18, 2006 Share Posted July 18, 2006 Save yourself hassle and take it to your trusted local exhaust/tyre place and get them to check it. (if it will get there). They can tell you if it is that (you dont HAVE to get them to do it though..........) Link to comment Share on other sites More sharing options...
dazzler24 Posted July 23, 2006 Author Share Posted July 23, 2006 Was the cat lads cheers.Brought a gti anyway cheers Link to comment Share on other sites More sharing options...
