L5 DOV Posted July 21, 2006 Share Posted July 21, 2006 i have gaz coilovers on my gti but one of them is jamed i have tryed everything i can think of to get the adjusting ring to move but havent ahd any joy. so my question is can i buy a new ring so i can cut the old one off and replace it or will i have to buy a whole new shock? i can buy this part on its own where will i get it from as i cant even find a website for gaz shocks thanks in advance for any help. Dave. Link to comment Share on other sites More sharing options...
dave_20 Posted July 21, 2006 Share Posted July 21, 2006 try a fookin big hammer lol if not i dont know if you can get new rings you sould b able to Link to comment Share on other sites More sharing options...
L5 DOV Posted July 21, 2006 Author Share Posted July 21, 2006 try a fookin big hammer lol if not i dont know if you can get new rings you sould b able to been there done that bent the adjusting spanner. Link to comment Share on other sites More sharing options...
dave_20 Posted July 21, 2006 Share Posted July 21, 2006 have u took it off the car? if so put it a tub of oil or sumthin Link to comment Share on other sites More sharing options...
L5 DOV Posted July 21, 2006 Author Share Posted July 21, 2006 have u took it off the car? if so put it a tub of oil or sumthin cheers m8 il try that im gonna take them all off and give them a good clean up when the cars away getting painted. Link to comment Share on other sites More sharing options...
Craig855S Posted July 21, 2006 Share Posted July 21, 2006 WD40,lots and lots of it Link to comment Share on other sites More sharing options...
sortedford Posted July 21, 2006 Share Posted July 21, 2006 id go with wd40, and a wire brush Link to comment Share on other sites More sharing options...
Ex-Finesse Posted July 21, 2006 Share Posted July 21, 2006 No WD-40 / any other lubricant / wire brush will solve this mate, sorry. The difference of metals between the ring and the shock thread has caused corrosion and they are fused together to a certain degree. If you cant turn it, all I can think of is to strip the unit down. Use spring compressors, and undo the assembly from the top, stripping it right down so u just have the main strut tube left with the corroded ring on it. Replace those 2 components, then reassemble. Easier said than done though mate. Unfortunately, adjustable race car suspension is meant for one place, the race track, and is not designed for road conditions without frequent servicing. Many companies will fail to mention this when you're about to order your £500 to £1k coilover suspension.. though. Link to comment Share on other sites More sharing options...
sortedford Posted July 21, 2006 Share Posted July 21, 2006 mine freed up fine with wd40 and a wire brush, gentral brushing hasnt damaged any of the thread, and made it very easy to adjust.put a spray greese on after setting it, which doesnt dissolve like wd40, then my covers ontop Link to comment Share on other sites More sharing options...
L5 DOV Posted July 21, 2006 Author Share Posted July 21, 2006 it dose move just, but i have to put a huge power bar on the end of the adjusting spanner to get it to move. no ideal as it takes ages about an hour for 4 turns infact and i have to take the unit off the car. is there anyway that it could have moved on the thread or that? dose ne1 know if i can buy the adjusting ring on its own and where i am likly to find this. thank you for all the help so far keep it coming. Link to comment Share on other sites More sharing options...
Devboy Posted July 22, 2006 Share Posted July 22, 2006 make sure once its loose to get some copper grease on there. Link to comment Share on other sites More sharing options...
Ex-Finesse Posted July 22, 2006 Share Posted July 22, 2006 You're not accidently forgetting to undo the grub screw, are you? If you can give it 4 turns, it should be mostly free by then! Link to comment Share on other sites More sharing options...
L5 DOV Posted July 23, 2006 Author Share Posted July 23, 2006 You're not accidently forgetting to undo the grub screw, are you? If you can give it 4 turns, it should be mostly free by then! no m8 i thot that to start with but the screw was almost out so its no that cheers for the feedback tho im gona take them off this week and have a good look at them. Link to comment Share on other sites More sharing options...
