MK6 electric window switches
STEPHEN
can switch be fiited in the door panel (say beside speaker) to operate the electric windows i already ahve a switch beside the gear stick but i keep going to the door to put my window up/down and thought mayb i could add a switch there
if this can b done would it be a matter of just joing into the wirng thats running 2 the switches already there or what is involved
cheers what sort of wire would b needed
anything can be done with enough work.
you will need to extend the loom and get it in to the door. 5 or 6 wires per switch so 10-12 for the windows.
if you have the electric boot release then thats another 4 wires.
you will then have to modify the door card to take the switch. fibreglass. and get a gearstick surround from a van or really low spec model. L or Encore.
if you just want to add a switch to the door, then get one from a mondeo sunroof or older granada.
like this
tons on ebay and for £2 posted a bargin.
it would be a case of run the wires to the door and up to the switch. use the sam size wires as already in place for the current switch.
wires:
2 will be for the LED, 1 up, 1 down and ground. well thats the way i would have thought they wire up.
