scott_d Posted March 4, 2003 Posted March 4, 2003 I topped up the oil in the pug cos the dash gague said it was low! so topped it up till it said it was full!then today i checked the dipstick and its about 5 mm over the max mark!! will this cause any damage?whats the easiest way to drain a little bit of oil? cheers scott
stuart Posted March 4, 2003 Posted March 4, 2003 let the sump plug out until it starts to drip alittle ( make sure you don't undo it to much )then check it til its at the right level and do it on the flat , ie , not jacked up >> :sonic: Stu.ART
Al Posted March 4, 2003 Posted March 4, 2003 Whilst it's never a good idea to overfill your oil, 5mm isn't too bad if you would rather leave it.Al.
scott_d Posted March 4, 2003 Author Posted March 4, 2003 Ok thanks, i will drain a bit off on the weekend. i wont get chance til then.
sortedford Posted March 4, 2003 Posted March 4, 2003 should have let it be propper cool and standin before you checked it mate
