ScORTED Posted June 23, 2007 Share Posted June 23, 2007 evening.. i'm inherriting a new car well not quite new but new to me... but its gearbox is fucked... and the gearboxes are 2 grand! anyone point me at a merc forum? Link to comment Share on other sites More sharing options...
PeeWee Posted June 23, 2007 Share Posted June 23, 2007 clicky Link to comment Share on other sites More sharing options...
ScORTED Posted June 23, 2007 Author Share Posted June 23, 2007 yeah i did the same search, i know a few people on here have mercs and thought they maybe able to point me to the right place? aslo without wanting to sound like a n00b does anyone know the mpdel designation of a T reg 2.6 V6 petrol ? the massive shpae one with quad headlights... i know the earlier ones a W123 and W124 so would this shape be a W125? Link to comment Share on other sites More sharing options...
Stu Posted June 24, 2007 Share Posted June 24, 2007 http://en.wikipedia.org/wiki/W124 Look down the bottom for the model number timeline.. Link to comment Share on other sites More sharing options...
sidrick Posted June 24, 2007 Share Posted June 24, 2007 I could help a lot here. Automatic? Link to comment Share on other sites More sharing options...
ScORTED Posted June 24, 2007 Author Share Posted June 24, 2007 yeah its a W210 E240 2.6 elegance Auto Link to comment Share on other sites More sharing options...
plumber60 Posted June 24, 2007 Share Posted June 24, 2007 Clicky Link to comment Share on other sites More sharing options...
sidrick Posted June 24, 2007 Share Posted June 24, 2007 You could spend more than the car is worth repairing that gearbox. Second hand units are dirty cheap as it's more than likely using the older style box used in the 210 chassais 190E. There's thousands of them Mercman - 02380 784444 will have what you need and deliver it to your door. You'll need a box code from the side of the autobox. PC Merc - 020 85565585 are another good source for Merc boxes and diffs. Link to comment Share on other sites More sharing options...
ScORTED Posted June 24, 2007 Author Share Posted June 24, 2007 thanks sidrick! the cars a 1999 - so i'd have thought despite a bit of surface rust and the problem its got to be worth fixing? its been suggested it could be a maf problm though. Link to comment Share on other sites More sharing options...
sidrick Posted June 24, 2007 Share Posted June 24, 2007 lol, quite a difference! What are the symptoms? The air flow meters on those things are prone to going. They're Seimens pish instead of decent Bosch ones. Link to comment Share on other sites More sharing options...
ScORTED Posted June 24, 2007 Author Share Posted June 24, 2007 If its left to idle till warm it will select drive and go ok, however after a while it slows down and struggles to do 40mph. If its driven from cold it often struggles to go at all. Often if the car is switched off and restarted it will be ok for a bit. Link to comment Share on other sites More sharing options...
sidrick Posted June 24, 2007 Share Posted June 24, 2007 (edited) Take it to a garage to get it diagnosed. Edited June 24, 2007 by sidrick Link to comment Share on other sites More sharing options...
ScORTED Posted June 24, 2007 Author Share Posted June 24, 2007 Would it be best to take it my local franchised dealer or a specialist? I've been told a few things to try re testing the maf so i'll give that a go first. any idea on the feasability of a manual conversion? Link to comment Share on other sites More sharing options...
sidrick Posted June 24, 2007 Share Posted June 24, 2007 (edited) Take the AFM off......... see what happens.I wouldn't take it to a dealer. £100+ an hour to tell you what you should already know.I doubt it's the gearbox, if it was limiting you to 40mph, then you'd hear it.You could always change the box oil and see if there's any solids caught up in the filter. Manual? A different prop and possibly diff. linkages and pedals.IF it's the box, an autobox would be simple as fcuk to find. But first you really need to find out what it is Edited June 24, 2007 by sidrick Link to comment Share on other sites More sharing options...
ScORTED Posted June 24, 2007 Author Share Posted June 24, 2007 sure i'll look into it, this is all what i've been told, i'll clean the maf and drive it tomorrow to find out. thankyou for your help sidrick Link to comment Share on other sites More sharing options...
