furqall Posted June 25, 2007 Share Posted June 25, 2007 the plastic doorstrips on my mk6 are colour coded and smooth, ive got another one to replace a dented one but the strip is grey and textured do i just spray it with a rattle can then laquer it? or do i have to spray it with a high build primer first or just rub it down first? Link to comment Share on other sites More sharing options...
PeeWee Posted June 25, 2007 Share Posted June 25, 2007 You will need to use plastic primer first mate. Link to comment Share on other sites More sharing options...
furqall Posted June 26, 2007 Author Share Posted June 26, 2007 cheers fella Link to comment Share on other sites More sharing options...
JC Posted June 30, 2007 Share Posted June 30, 2007 Sand the grey strip first, just enough to roughen the surface, this helps the primer to stick better, use plastic primer as PeeWee said, use wet and dry to smooth the primer off before painting. Link to comment Share on other sites More sharing options...
Dubs Posted June 30, 2007 Share Posted June 30, 2007 Get some plastic filler primer from halfords mate obviously its for plastic and its high build aswell. Link to comment Share on other sites More sharing options...
