escortgti.com Posted June 25, 2007 Share Posted June 25, 2007 Must be in full working order And also able to post asap and first class if poss ! CheersGregor Link to comment Share on other sites More sharing options...
reid Posted June 25, 2007 Share Posted June 25, 2007 got one just taken off a 1.8 SI, offer? canpost 1st class 2moro morn Link to comment Share on other sites More sharing options...
escortgti.com Posted June 25, 2007 Author Share Posted June 25, 2007 got one just taken off a 1.8 SI, offer? canpost 1st class 2moro morn The GTi has abs mate not sure if that makes a difference ? Link to comment Share on other sites More sharing options...
Carl160180 Posted June 25, 2007 Share Posted June 25, 2007 (edited) Why are you after a caliper? are the brakes binding on that side? If so i'd put money on that fact that it's the brake flexi hose that's collapsed and not the caliper at fault! Had LOADS of these in the garage I used to work at, it's a common fault on the mk6's! Easiest way to chack is try pushing the piston back in the caliper, If it won't budge crack the bleed nipple off or the brake hose into the caliper, If it goes back after doing that then it's 100% the flexi Edited June 25, 2007 by Carl160180 Link to comment Share on other sites More sharing options...
reid Posted June 25, 2007 Share Posted June 25, 2007 met him earlier with the caliper, STUNNING car he's got. standard gti but VERY clean and dropped on its arse with mint 17" softspokes hiding under there. Link to comment Share on other sites More sharing options...
