Wiggy Posted June 26, 2007 Share Posted June 26, 2007 im gettin a new one soon , got the gasket already. Now i dont wanna fcuk it up and i cant be arsed 2 pay a mechanic for an easy job Anyone got a guide for it? Link to comment Share on other sites More sharing options...
Stu Posted June 26, 2007 Share Posted June 26, 2007 Er. 1. Remove bolts.2. Remove cover.3. Clean cover, thoroughly.4. Fit new silicone seal.5. Re-fit cover.6. re-fasten bolts. Link to comment Share on other sites More sharing options...
Andy 3i Posted June 26, 2007 Share Posted June 26, 2007 undo 10mm bolts, remove cover and gasket. replace gasket and place cover ontop and tighten. depending on wether you have your air intake crossing your rocker cover then that would have to be removed first. Link to comment Share on other sites More sharing options...
Wiggy Posted June 26, 2007 Author Share Posted June 26, 2007 is it really that simple eh... Link to comment Share on other sites More sharing options...
Stu Posted June 26, 2007 Share Posted June 26, 2007 Andy likes repeating. Link to comment Share on other sites More sharing options...
Wiggy Posted June 26, 2007 Author Share Posted June 26, 2007 Posted within 1 minute of each other Link to comment Share on other sites More sharing options...
Andy 3i Posted June 26, 2007 Share Posted June 26, 2007 i didnt intend to, you posted just before i did! Link to comment Share on other sites More sharing options...
Stu Posted June 26, 2007 Share Posted June 26, 2007 Oh, I misread the times. I take it all back. Link to comment Share on other sites More sharing options...
Andy 3i Posted June 26, 2007 Share Posted June 26, 2007 good good. making me out to be a copy cat! Link to comment Share on other sites More sharing options...
Wiggy Posted June 26, 2007 Author Share Posted June 26, 2007 lol cheers ladies ^^ Link to comment Share on other sites More sharing options...
Andy 3i Posted June 26, 2007 Share Posted June 26, 2007 no worries mate! Link to comment Share on other sites More sharing options...
revoltos Posted June 26, 2007 Share Posted June 26, 2007 Also tighten back up to the correct torque as your bolting into an alloy head, tighten bolts in opposites to not round in a circle. Link to comment Share on other sites More sharing options...
xrtom Posted June 26, 2007 Share Posted June 26, 2007 Hardest bit may be taking the tb off if its in the way as mentioned above. Last time i changed mine got one from the scrappy, cleaned it and sprayed it with some very high temperature paint from hal-frauds. Looked quite good with a stainless spark plug cover but like any painting if ya gonna do it take ya time and do it properly. Link to comment Share on other sites More sharing options...
Stu Posted June 27, 2007 Share Posted June 27, 2007 I've never had to remove a throttle body to get the cam cover off, on either manifold style. And sure, you can torque up the bolts. 8 ft-lb should do it as they're M6. You really don't need to be so hardcore though, just nip them with a 1/4 ratchet and you'll be sorted. Link to comment Share on other sites More sharing options...
