escortgti.com Posted June 27, 2007 Share Posted June 27, 2007 Bleeding the brakes on a Ford Escort. I have bled as the haynes states : Passenger FrontDriver RearDriver FrontPassenger Rear Problem is, no fluid will go through the driver front caliper.I took the brake pipe off the caliper to find that no fluid was coming through there either ! To make sure I hadnt knackered the master cylinder etc , I checked that the passenger rear would still bleed even though the driver front wouldnt. It bled fine ! So is something blocking the Drivers front brakeline ? How can I sort this ? Link to comment Share on other sites More sharing options...
ScORTED Posted June 27, 2007 Share Posted June 27, 2007 replace the said brake line - or take it off both ends and blow it through with compressed air Link to comment Share on other sites More sharing options...
escortgti.com Posted June 27, 2007 Author Share Posted June 27, 2007 replace the said brake line - or take it off both ends and blow it through with compressed air Once Ive done that do I need to re-bleed the whole car ? Link to comment Share on other sites More sharing options...
ScORTED Posted June 27, 2007 Share Posted June 27, 2007 as long as you don't operate the brakes while the line is off you should be ok... if you operate them the mastercylinder may suck air into the system Link to comment Share on other sites More sharing options...
escortgti.com Posted June 27, 2007 Author Share Posted June 27, 2007 balls , re-bleeding the lot then What would cause this ? Dirt ? Link to comment Share on other sites More sharing options...
sidrick Posted June 27, 2007 Share Posted June 27, 2007 Deteriorated brake hose. Link to comment Share on other sites More sharing options...
ScORTED Posted June 27, 2007 Share Posted June 27, 2007 if you are still on the original rubber hoses its perfectly feasible on oculd have collapsed Link to comment Share on other sites More sharing options...
mexico_16v Posted June 27, 2007 Share Posted June 27, 2007 if you are still on the original rubber hoses its perfectly feasible on oculd have collapsedIt is not uncommon for the brake hose to break down inside, get some good uprated jobbies Link to comment Share on other sites More sharing options...
escortgti.com Posted June 27, 2007 Author Share Posted June 27, 2007 But the brakes were fine beforehand , and look fine as is ? Link to comment Share on other sites More sharing options...
mexico_16v Posted June 27, 2007 Share Posted June 27, 2007 But the brakes were fine beforehand , and look fine as is ?on a dual line master cyclinder, which you would have you have two split line's one going to the nearside rear and the offside front, the other to the nearside front and offside rear, check that the oppisite (spelt wrong i know) side off that duel line is bleeding fine, if not then the master cyclinder is fcuk'd, if you find it is bleeding fine, then replace that brake hose and it'l be fine. Link to comment Share on other sites More sharing options...
sidrick Posted June 27, 2007 Share Posted June 27, 2007 It's like one elongated echo in here. Hello!!! hello...... hello..... hello...... Link to comment Share on other sites More sharing options...
escortgti.com Posted June 27, 2007 Author Share Posted June 27, 2007 Cheers mexico. Sidrick what ? Link to comment Share on other sites More sharing options...
mexico_16v Posted June 27, 2007 Share Posted June 27, 2007 Cheers mexico. Sidrick what ?He like's bum fun leave him be! Link to comment Share on other sites More sharing options...
bluliz Posted June 27, 2007 Share Posted June 27, 2007 hello... Link to comment Share on other sites More sharing options...
sidrick Posted June 27, 2007 Share Posted June 27, 2007 Cheers mexico. Sidrick what ?He like's bum fun leave him be! He Fcuking does! So watch out. Link to comment Share on other sites More sharing options...
