M44K TS Posted July 1, 2007 Share Posted July 1, 2007 As above really, my van has the boring black dials and digi miles but no rev couner. Quick question, would Pum dials fit and work? They look the same and i know i would have to run the signal wire from the altenator to get the rev counter working. Any ideas? Link to comment Share on other sites More sharing options...
Stu Posted July 1, 2007 Share Posted July 1, 2007 I would have thought so.. Link to comment Share on other sites More sharing options...
stoo2000 Posted July 1, 2007 Share Posted July 1, 2007 the later escort van, and the last escorts came with these digital dials, VanMan_Jas figured out most of the wiring for them Almost forgot too, we've got a user submitted guide here: http://www.escortevolution.co.uk/howto/view.php?id=58 Link to comment Share on other sites More sharing options...
M44K TS Posted July 1, 2007 Author Share Posted July 1, 2007 cool, as i say, my van alrady has the same style dials in with the digi miles so i was hoping for a straight swap Link to comment Share on other sites More sharing options...
RyanML Posted July 1, 2007 Share Posted July 1, 2007 puma/fiesta dails are identical to the escort ones, and if your van already has the digital part they should go straight in, but im sure that somthing on them wont work or somthing im not sure, but they will fit in there lol. Link to comment Share on other sites More sharing options...
M44K TS Posted July 1, 2007 Author Share Posted July 1, 2007 excellent stuff, a mate of mine has a spare set lying about, might try and twist his arm so he sells me them :lol: Link to comment Share on other sites More sharing options...
Craig855S Posted July 1, 2007 Share Posted July 1, 2007 if ur digi's up already then they shud work,the tacho may need the feed wired in,apparently the rev feed on TDs is from the alternator, if u got a petrol its a plug on the ECU, check haynes for which one Link to comment Share on other sites More sharing options...
white_van_man Posted July 2, 2007 Share Posted July 2, 2007 yep for tacho feed on diesels you normally just run a wire from the spare terminal on alternator up to pin8 on the blue connector in the dash but being that you have digi clock set the terminal where the tacho feed comes in will be different probably you'd need to check some wiring diagrams Link to comment Share on other sites More sharing options...
M44K TS Posted July 2, 2007 Author Share Posted July 2, 2007 i'll bare that in mind, i'll have a go at putting them in and seeing if they work first then i'll try linking the tacho in oh and by the way, the thread title should say MK6 not mk6 Link to comment Share on other sites More sharing options...
M44K TS Posted July 4, 2007 Author Share Posted July 4, 2007 Huzzah! Not one, but three sets of digi dials. Winner!!!!!!!! Tomorrows job, plug them in and see if they work. I have been told 2 of the sets are Fiesta and one Puma Lets see which ones fit Link to comment Share on other sites More sharing options...
meekstaaa Posted July 5, 2007 Share Posted July 5, 2007 wanna send us a set!? Link to comment Share on other sites More sharing options...
M44K TS Posted July 5, 2007 Author Share Posted July 5, 2007 unfortunatley, only 1 set is mine, my mate who i've got them off want 2 of the others back but he gave me the choice of 3. I can have a word with him if you want and see if he'll sell you a set? Link to comment Share on other sites More sharing options...
Hezz Posted July 5, 2007 Share Posted July 5, 2007 i think that puma / fiesta and escort ones are all the same - have they got differing part numbers? Link to comment Share on other sites More sharing options...
JC Posted July 5, 2007 Share Posted July 5, 2007 puma/fiesta dails are identical to the escort ones, and if your van already has the digital part they should go straight in, but im sure that somthing on them wont work or somthing im not sure, but they will fit in there lol. My escort had digi dials to start with and were a straight swap over for white puma dials, everything worked fine Link to comment Share on other sites More sharing options...
M44K TS Posted July 5, 2007 Author Share Posted July 5, 2007 just tried all 3 sets, Puma clocks the airbag light is always on. Other 2 fiesta ones are fine. Only problem is, my van didn't have a rev counter to start off with. Anyone know ehich pin on the 32 pin clock plug the rev counter signal goes to I don't want to start just trying any pin incase i blow something up lol Link to comment Share on other sites More sharing options...
