ronal escort 1.8 16v Posted July 5, 2007 Share Posted July 5, 2007 hi can anyone tell me if i could fit a 2.0l throttle body and ecu and maf sensor to my 1.8 ghia and if it would make any difference? thanks! Link to comment Share on other sites More sharing options...
xrtom Posted July 5, 2007 Share Posted July 5, 2007 hi can anyone tell me if i could fit a 2.0l throttle body and ecu and maf sensor to my 1.8 ghia and if it would make any difference? thanks! Not really mate although yes they are bigger than the standard 105 if you have a ghia it wont really do sweet fa. The only difference would be if you had aghia si fitted with the 130 engine and a 105 tb for some reason then it would only be worth doing as the tb would be restricting the airflow. Overwise the tb on your engine already works well enough Link to comment Share on other sites More sharing options...
madxrcabby Posted July 5, 2007 Share Posted July 5, 2007 hi can anyone tell me if i could fit a 2.0l throttle body and ecu and maf sensor to my 1.8 ghia and if it would make any difference? thanks! Not really mate although yes they are bigger than the standard 105 if you have a ghia it wont really do sweet fa. The only difference would be if you had aghia si fitted with the 130 engine and a 105 tb for some reason then it would only be worth doing as the tb would be restricting the airflow. Overwise the tb on your engine already works well enough either that or if he has the 105 spec engine you could 130 spec it Link to comment Share on other sites More sharing options...
xrtom Posted July 6, 2007 Share Posted July 6, 2007 either that or if he has the 105 spec engine you could 130 spec it yeah if its just a ghia and not a ghia si it will be 105 Link to comment Share on other sites More sharing options...
ronal escort 1.8 16v Posted July 9, 2007 Author Share Posted July 9, 2007 its 1 15 psi Link to comment Share on other sites More sharing options...
