tezmanian devil Posted July 8, 2007 Share Posted July 8, 2007 evening all. im fitting a efi rst engine in my 3i, but have a few question's, and will no dout be asking more soon lol first of all, how do i keep my power steering, the rst didnt have it so where/how do i get a p/s pump? 2nd question: what engine mounts do i use? can i jus use normal mk5 cvh engine mounts? 3rd question: what sort of part's do i need for a reliable 200bhp (roughly) a list would be very helpful 4th question: what would need to be done to convert in to a 1.8 zvh, or 2.0 zvh, i know oil/water way's need blocking, but how do you do this, and are zvh very reliable, as i think blocking off oil/water way's cant be doin it any favor's... 5th question: who do you recommend to tune it all when it's all done and fitted?? 6th question: how do you time up a rs turbo engine? 7th question: how do you get the piston's off the conrod's (got new conrod's that need fitting to the piston's, but cant get them off ) sorry about all the question's but any help on the above would be great, as i dont really know a great deal atm Link to comment Share on other sites More sharing options...
bluliz Posted July 8, 2007 Share Posted July 8, 2007 2nd question: what engine mounts do i use? can i jus use normal mk5 cvh engine mounts? Yup a CVH is a CVH, so just use some 1.4 mounts. does you 3i have cvh or zetec? can never remember on the mk5a's. Link to comment Share on other sites More sharing options...
Stu Posted July 8, 2007 Share Posted July 8, 2007 first of all, how do i keep my power steering, the rst didnt have it so where/how do i get a p/s pump?I believe you can hack up a CVH PAS setup onto an RST engine. I don't know the specifics though. 2nd question: what engine mounts do i use? can i jus use normal mk5 cvh engine mounts?Yes. 3rd question: what sort of part's do i need for a reliable 200bhp (roughly) a list would be very helpful 'Stage 3' Hybrid T3 (50 trim compressor with a 0.48 A/R turbine). Big enough injectors. Different map sensor. Suitable custom remap. Big intercooler. Exhaust system. Suitable fuel pump. Preferably slightly lower compression (skim 0.060" off the standard Mahle pistons). 4th question: what would need to be done to convert in to a 1.8 zvh, or 2.0 zvh, i know oil/water way's need blocking, but how do you do this, and are zvh very reliable, as i think blocking off oil/water way's cant be doin it any favor's...Why on earth would you want to do that? Why throw away the best bit of a zetec engine (the head) and bolt on the worst part of a CVH engine (the head)? 5th question: who do you recommend to tune it all when it's all done and fitted??Ahmed Bayjoo. 6th question: how do you time up a rs turbo engine?Assuming you're still asking about a EFI engine, then, you don't. 7th question: how do you get the piston's off the conrod's (got new conrod's that need fitting to the piston's, but cant get them off )With heat. Why are you doing this? Link to comment Share on other sites More sharing options...
Wiggy Posted July 8, 2007 Share Posted July 8, 2007 Stu to the rescue Link to comment Share on other sites More sharing options...
turbosy Posted July 8, 2007 Share Posted July 8, 2007 how do i keep my power steering, the rst didnt have it so where/how do i get a p/s pump?The early MK5 escort 1.6 CVH EFIs had power steering, use that........and the engine mounts, you could use the engine loom, if you are using FRST ECU etc. You just need to swap 2 or 3 wires over, at the ECU, iirc Link to comment Share on other sites More sharing options...
reid Posted July 8, 2007 Share Posted July 8, 2007 how do i keep my power steering, the rst didnt have it so where/how do i get a p/s pump?The early MK5 escort 1.6 CVH EFIs had power steering, use that........and the engine mounts, like mine. bolt it off the CVH engine and onto your turbo lump, 1 bolthole wasnt there but the 2 bolts hold it strong enough. Link to comment Share on other sites More sharing options...
sortedford Posted July 8, 2007 Share Posted July 8, 2007 do you currently have a t2 or t3? t2 the turbo will sit in the way of where the p/s is going.I have a wickid electric hydraulic pump for power stearing im selling (all it requires is a 12v- so it doesnt run off a belt), someones interested atm, but if he dont want it il let you know Link to comment Share on other sites More sharing options...
ScORTED Posted July 9, 2007 Share Posted July 9, 2007 speak to jano @ oddkiddcreations tez... he's near you isn't he? and you don't need efi for 200bhp - will cost you a lot more to get 200bhp from EFi than MFi Link to comment Share on other sites More sharing options...
Stu Posted July 9, 2007 Share Posted July 9, 2007 speak to jano @ oddkiddcreations tez... he's near you isn't he? and you don't need efi for 200bhp - will cost you a lot more to get 200bhp from EFi than MFi Not quite how it is. You instantly gain maybe 20bhp on an identical engine spec going from MFI to EFI due to the better airflow. But ultimately yes, it will cost more to achieve the same (if you want 200bhp and nothing but). Link to comment Share on other sites More sharing options...
iwantacosworth Posted July 11, 2007 Share Posted July 11, 2007 So as long as i get a Mk5 with a Cvh engine thast has p/s I can drop in an Rs turbo lump and utilise the p/steering that is on the original engine? Link to comment Share on other sites More sharing options...
reid Posted July 11, 2007 Share Posted July 11, 2007 So as long as i get a Mk5 with a Cvh engine thast has p/s I can drop in an Rs turbo lump and utilise the p/steering that is on the original engine? aye. but bear in mind your car has to have a rack that can use PS. Link to comment Share on other sites More sharing options...
iwantacosworth Posted July 11, 2007 Share Posted July 11, 2007 cheers Reid - its a fair while off yet but good to know! Link to comment Share on other sites More sharing options...
Yule Posted July 11, 2007 Share Posted July 11, 2007 How's yours comin along reid? picked mine up today after having a new loom put in & new coil pack, still gotta get a cpl bits done before ford fair. Link to comment Share on other sites More sharing options...
tezmanian devil Posted July 20, 2007 Author Share Posted July 20, 2007 first of all, how do i keep my power steering, the rst didnt have it so where/how do i get a p/s pump?I believe you can hack up a CVH PAS setup onto an RST engine. I don't know the specifics though. 2nd question: what engine mounts do i use? can i jus use normal mk5 cvh engine mounts?Yes. 3rd question: what sort of part's do i need for a reliable 200bhp (roughly) a list would be very helpful 'Stage 3' Hybrid T3 (50 trim compressor with a 0.48 A/R turbine). Big enough injectors. Different map sensor. Suitable custom remap. Big intercooler. Exhaust system. Suitable fuel pump. Preferably slightly lower compression (skim 0.060" off the standard Mahle pistons). **so i couldnt use my magnex that i have on there atm then? what intercooler would you reccomend? would a cossie fuel pump be good enough, or even too good maybe ** 4th question: what would need to be done to convert in to a 1.8 zvh, or 2.0 zvh, i know oil/water way's need blocking, but how do you do this, and are zvh very reliable, as i think blocking off oil/water way's cant be doin it any favor's...Why on earth would you want to do that? Why throw away the best bit of a zetec engine (the head) and bolt on the worst part of a CVH engine (the head)? ** jus thought that maybe i could get more power from it if it wer zvh...** 5th question: who do you recommend to tune it all when it's all done and fitted??Ahmed Bayjoo. 6th question: how do you time up a rs turbo engine?Assuming you're still asking about a EFI engine, then, you don't. ** well it was a mfi engine, but im puttin efi bit's on it, which will lead to a yet another question at the bottom lol** 7th question: how do you get the piston's off the conrod's (got new conrod's that need fitting to the piston's, but cant get them off )With heat. Why are you doing this? **because one if the conrod's has got a bolt stuck in it, on the big end side, where the 2 bolt's hold the piston on the crank shaft... one of the head's broke off so can get the rest out ** everything's been put on hold for now, but i have put star's next to where i'v replied above so i know for when i do start back on it and another question, lol, this engine i got, it was a mfi one, and im wanting to put efi bit's on it,... but will everything actually fit, like the inlet and exhaust manifold etc, and all the other bit... basically, is there anything that wouldnt allow me to use efi bit's? Link to comment Share on other sites More sharing options...
reid Posted July 21, 2007 Share Posted July 21, 2007 you can use your own exhaust as long as you modify the downpipe to fit onto the turbo manifold, thats what ive did for the time being. Link to comment Share on other sites More sharing options...
