Fitting my sub, Please help
MattieW
In relation to your original question, remove passenger wheel, remove arch lining & you will see a big gromet, you can make a slice in this then pop the power cable from the battery into the arch then through the grommet where it should then appear in the footwell, it can then be routed along under the plastc cowlings to the boot. :thumb:
