vernam616 Posted July 10, 2007 Share Posted July 10, 2007 alryt people, my brother has recently bought a escort LX, and is in the process of making it look like a GTi, we were wondering how hard it is to change the standard steering wheel to the GTi leather one/and if so , how to do it? Dan Link to comment Share on other sites More sharing options...
madxrcabby Posted July 10, 2007 Share Posted July 10, 2007 have a search around mate , question has been asked a few times before Link to comment Share on other sites More sharing options...
paul7278 Posted July 22, 2007 Share Posted July 22, 2007 remove couling from around the stearing wheel, undo the 4 tiny (4.5mm) ish bolts holding the airbag to the stearing wheel, disconect battery and pull off cable that powers the airbag then undo the 21mm bolt holding the stearing wheel on then replace with new one! esy mate i tried it but unfortuantly my new stearing wheel came off a fiesta so the horn was on the stalk and it didnt work so good lol but will be fine with a gti/si stearing wheel! Link to comment Share on other sites More sharing options...
lazy_arse_pie Posted July 22, 2007 Share Posted July 22, 2007 i didnt have to remove the couling when ive changed both my steering wheels Link to comment Share on other sites More sharing options...
PeeWee Posted July 22, 2007 Share Posted July 22, 2007 Disconnect the batery for about an hour before starting to be safe.Remove plastic cowling top & bottom.Airbag bolts are 5.5mm recessed at the rear of the wheel,turn wheel to each side to get access.once out give the airbag a tug to release it off its lugs & disconnect the yellow connector.Center wheels & engage steering lock while you undo center bolt, release steering lock & wiggle free & pull the wheel free.Fitting is the reverse of removal. Link to comment Share on other sites More sharing options...
