quackers Posted August 12, 2007 Share Posted August 12, 2007 Picture the scene, its a nic sunny day, sunroof down, windows open. My windscreen is a bit dirty, so i decide to use the window wash. Fcuk me! The smell! it's like rotten cheese lol It appears the water has gone off ? Is that possible? What's the best course of action? Help Link to comment Share on other sites More sharing options...
damian Posted August 12, 2007 Share Posted August 12, 2007 Picture the scene, its a nic sunny day, sunroof down, windows open. My windscreen is a bit dirty, so i decide to use the window wash. Fcuk me! The smell! it's like rotten cheese lol It appears the water has gone off ? Is that possible? What's the best course of action? Help empty and refill Link to comment Share on other sites More sharing options...
cargy Posted August 12, 2007 Share Posted August 12, 2007 Link to comment Share on other sites More sharing options...
ScORTED Posted August 12, 2007 Share Posted August 12, 2007 yes cheap screen wash can indeed go off... drain it, check theres no shite gunk clogging up the bottle also halfrauds do scented stuff, stay away from the lemon though, it smells like smirnoff ice... not good at 9am Link to comment Share on other sites More sharing options...
quackers Posted August 12, 2007 Author Share Posted August 12, 2007 What's the best way to empty it? Can it be done from underneath? Link to comment Share on other sites More sharing options...
pantherblacksi Posted August 12, 2007 Share Posted August 12, 2007 at last some one with the same problem..mine has been emptyed and refilled many times but still gives out bad smelling water..how hard is it to change the washer bottle for a new 1 Link to comment Share on other sites More sharing options...
meekstaaa Posted August 12, 2007 Share Posted August 12, 2007 you'll need to take the front bumper off mate and then its 3 10mm bolts 2 are easy to do but theres one that's in a really tight gap! Link to comment Share on other sites More sharing options...
Joe Posted August 12, 2007 Share Posted August 12, 2007 I had this problem, made me sick! Dont remove the front bumper! Remove the front passenger mud gaurd! Look at the bottle, pull out the filter thing, and it will stink!! Prod and poke, to allow it to really empty! Be warned., its HORRID Link to comment Share on other sites More sharing options...
caled Posted August 12, 2007 Share Posted August 12, 2007 just the mud guard? am i getting that confused with the mud flaps or is it that easy to get to? Link to comment Share on other sites More sharing options...
escort tink Posted August 13, 2007 Share Posted August 13, 2007 yor could always get a hose pipe and flush it out by letting it over flow just pop the hosepipe in the hole and pust it to the bottom and let it all over flow Link to comment Share on other sites More sharing options...
shawdreamer Posted August 13, 2007 Share Posted August 13, 2007 for godsake...............JUST DROP A SODDIN TOILET BLUE BLOCK IN IT! its basically algae and bacteria growing on the inside of the tank..... emptying and refilling it only causes the algae to die back slightly then come back with avengence, a toilet duck block (the none bleach one) kills the lot off then all you need to do is leave it in there till its totally disintrigarated weeks later and then allways make sure you add a nit of screen wash to your water when you refill (that stops the algae growing again) Link to comment Share on other sites More sharing options...
escort tink Posted August 13, 2007 Share Posted August 13, 2007 good old toilet blue Link to comment Share on other sites More sharing options...
Joe Posted August 13, 2007 Share Posted August 13, 2007 just the mud guard? am i getting that confused with the mud flaps or is it that easy to get to? Not the mud flaps, the mud guard (big thing in the arches) Remove, remove filter, prod and poke, watrer should Pee out, give it a clean, ir do as the 'dreamer' says. Link to comment Share on other sites More sharing options...
