IBD4vid Posted August 12, 2007 Share Posted August 12, 2007 hi i need to repare the head gasket on my mk6 engine is it easyer to change engine or to repair the gasket? all ur help will be very helpful Link to comment Share on other sites More sharing options...
speedy Posted August 12, 2007 Share Posted August 12, 2007 head gasked it rearly easy to do its just down to what u no about timing thow as cam belt has to come of and back on a certain way to avoide causing damage and head bolts nead to be torqued down correct and in a sertain pattern but buy far easier than doing an engine unless u was thinking more power in that case 2.0 is the way forward and with removal of belt new belt should be fitted with tenshioners and new head bolts and gaskets should also be replaced Link to comment Share on other sites More sharing options...
IBD4vid Posted August 12, 2007 Author Share Posted August 12, 2007 na i only wanted a 1.6I zetec nothing more so i might aswell change the whole engine Link to comment Share on other sites More sharing options...
Stu Posted August 12, 2007 Share Posted August 12, 2007 The ease of a job depends on your ability.. what have you done before and how hard did you find it? Link to comment Share on other sites More sharing options...
ScORTED Posted August 12, 2007 Share Posted August 12, 2007 speak to reid he said you can make one fro ma large cornflakes box some pva glue and a small aubergine Link to comment Share on other sites More sharing options...
reid Posted August 12, 2007 Share Posted August 12, 2007 (edited) speak to reid he said you can make one fro ma large cornflakes box some pva glue and a small aubergine FPMSL fook off ya tool its true tho.. Edited August 12, 2007 by reid Link to comment Share on other sites More sharing options...
